lala
Level IX
How can I save a JMP table in JMP 18 without leaving a record in the file list?
The same code is not recorded in JMP17.
dt = Open( "$SAMPLE_DATA/Big Class.jmp", Add to Recent Files( 0 ) );
dt << Select Where( Row() < 21 );
d3 = dt << Subset( Output Table( "AA" ), Selected Rows( 1 ), selected columns( 0 ) );
Try( d3 << Delete Table Property( "Source" ) );
d3 << Save( "c:\test.jmp" );
Close( dt, nosave );
Close( d3, nosave );
Re: How can I save a JMP table in JMP 18 without leaving a record in the file list?
In case the data tables are invisible - at least for me they then do not show up in my recent files list when saving them
dt = Open( "$SAMPLE_DATA/Big Class.jmp", Add to Recent Files( 0 ) , invisible);
d3 = dt << Subset( Output Table( "AA" ), Selected Rows( 1 ), selected columns( 0 ) , invisible);
d3 << Save( ".\test.jmp" );
/****NeverStopLearning****/
Level XIII
thanks for the trick with Add to Recent Files(0).
Nice trick : )
I just noticed the
preferences("Add files opened by scripts to the Recent Files list")
For save, I hope somebody will provide a solution ...
