How can I prevent JMP to open a new Home window
Currently I use JMP version 17.0.0 on Windows 10.
My problem is when I have Home Window opened and click JMP/JSL file to open, My JMP will open a new Home Window that I not want to be like this.
I have used JMP 16 before and never seen this problem before.
How can I prevent JMP to open a new Home window after open from JMP file when have current Home window opening.
Re: How can I prevent JMP to open a new Home window
Assuming you are running on a PC, the first thing you should try is to reset the file associations.
Go to
      File=>Preferences=>Window Specific
Towards the bottom the displayed window, click on the button
     Reset Associations
Hi Jim,
I am running on my laptop. And I tried to Reset Associations but it doesn't work.
Its still open a new HOME windows when I double click at JMP file.
If I drag and drop JMP file into JMP, It's OK to me because JMP not open a new HOME windows.
Any other things I can do ?
Please see my screen record in the attached.
kevinliu
Hi Jim,
It seems like the old discussion methods wont work anymore. It seems happened right after the new version of JMP 17 update. I am wondering whether there are any new or general solution we can try.
Best,
Kevin
If the previously described methods are not fixing he issue, then I suggest that you contact JMP Support.
