lala
Level IX
How can I modify the default Settings of the Hover Labels Editor in my software?
I want to modify the contents of the "Textlet" in this "Hover Labels Editor" in the default Settings of the software and let it open automatically.
This allows the software to start and execute the new content.
Re: How can I modify the default Settings of the Hover Labels Editor in my software?
I'm not sure what you want to modify and how? Do you want to be able to open that menu automatically? What should trigger this "automatically"?
Level XIII
If you want every graph to have a default Hover Label settings like this one,
...maybe half-way to the ultimate solution:
add an icon to the toolbar which executes a code like the below one.
Then, whenever you need this type of Hover Label, you can apply it with a single mouse click.
Alterantive: define a menu item and link it to a Keyboard Shortcut.
fbs = Current Report() << xpath( "//FrameBox" );
fbs << Set Textlet(
	Setup( local:encodedWhere = XML Encode( local:_age ) ),
	Markup( "<b> Age</b>: {local:_age}
Level XIII
@jules , I wonder if this is an application case for Platform Presets.
It's just a single setting which has to be applied.
So the preset has to recorded before any additional setting is defined (like value on the x and y axis etc).
lala
Level IX
  • This reduces the need to write JSL.
  • Just for the machine, of course.
