simon_2
How can I highlight data points when clicking on legend in interactive HTML?
I have a bivariate chart saved as interactive HTML. I would like to be able to select a legend and highlight points on the chart. Is it possible to do this using JSL?
This is the chart after saving as interactive HTML.
Here is the JSL script:
biv = dt << Bivariate(
	Y( :height ),
	X( :weight ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Frame Size( 448, 348 ), Row Legend(
				sex,
				Color( 1 ),
				Color Theme( "JMP Default" ),
				Marker( 1 ),
				Marker Theme( "Standard" ),
				Continuous Scale( 0 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
rbiv = biv << report;
rbiv << Save Interactive HTML( "height_weight_chart.html" );
Thanks.
Re: How can I highlight data points when clicking on legend in interactive HTML?
Legends aren't interactive in Interactive HTML, unfortunately. But you can achieve something close using a dashboard:
simon_2
Thanks
Thanks for your question, @simon_2. In JMP 17, HTML5 supports interactive legends in Graph Builder reports.
simon_2
 Cool. Looking forward to using JMP 17.
