I have a bivariate chart saved as interactive HTML. I would like to be able to select a legend and highlight points on the chart. Is it possible to do this using JSL?
This is the chart after saving as interactive HTML.
Here is the JSL script:
biv = dt << Bivariate(
Y( :height ),
X( :weight ),
Dispatch(
"Bivar Plot",
FrameBox,
{Frame Size( 448, 348 ), Row Legend(
sex,
Color( 1 ),
Color Theme( "JMP Default" ),
Marker( 1 ),
Marker Theme( "Standard" ),
Continuous Scale( 0 ),
Reverse Scale( 0 ),
Excluded Rows( 0 )
rbiv = biv << report;
rbiv << Save Interactive HTML( "height_weight_chart.html" );
Thanks.
