Ripple
How can I format "Show Percents" text?
How can I format the percent text that appears appears above bars in a histogram when I turn on Show Percents?  The default format is deficient in several ways: 1) It is smaller than I would like it to be; 2) The percent values are whole numbers such as "1%" (I want to be able to show the values at finer resolution in decimal form such as "0.8%"); 3) There is no background color behind the text (I'd like to choose white) and thus the gridlines of the graph run right through the percent values, making them harder to read.  All of these things are easily, quickly, and intuitively changed in Excel - but after continued searching I haven't found a way to choose my own format in JMP.  Anyone know how to do it?
Re: How can I format "Show Percents" text?
I am not aware of any way within the Histogram Platform to make the changes to the Percents as you have specified.  Also, the percent objects on the histogram are not surfaced to the Frame Box() of the histogram. So, using the Customize to modify them is not available.  However, a script could be written to calculate the percentages, and then apply them on top of the Histogram Frame Box().  It would be a bit of a challenge, but it could be done.
Ripple
Thanks.  Bummer - seems like functionality that should be there.
I agree, and I suggest that you send to
     [email protected]
BTW, if you are not aware, you can manually annotate your own percents onto the graph, using the annotation tools in JMP.
