How can I fix the decimal place in Y-axis in control chart builder?
I have a problem to fix the decimal place in Y-axis label.
Here is my problem.
1. I want to get two decimal places in Y-axis label.
2. I set the decimal place using Axis setting, and selected Fixed Dec with Dec=2
3. And then, graph was applied with 2 deciaml places.
4. After the confirmation, I saved setting and scritp was also confirmed.
5. Close the window, and re-run the script, the decimal place was back to 0. But in script, I can find that the code with with 2 dec.
How can I fix the decimal places like this situation?
Please help me.
Thank you in advance.
SamGardner
Re: How can I fix the decimal place in Y-axis in control chart builder?
This is a known issue, and there is currently not a way to fix the decimal places for the display of the labels on the chart.  An existing wishlist item requesting this capability and this is being addressed by development.  https://community.jmp.com/t5/JMP-Wish-List/Fix-issue-with-variable-number-of-decimals-shown-in-the-U...
Try changing the format in the data table for your X axis column to have 2 decimal places.  That may do the trick.
I also tried it, but it cannot work.. but thank you for your advice.
David_Burnham
I wasn't able to reproduce this ... I wonder if it is dependent of the version of JMP ... what version are you running?
-Dave
SamGardner
