mdeng
How can I extract Ppk values whenever data is updated?
Hi
I want to extract the Ppk values whenever the data is updated. Can someone direct me on how to use scripting or other methods to obtain Ppk values?
Thanks
Margaret
Re: How can I extract Ppk values whenever data is updated?
Few questions:
  • How is Ppk calculated?
  • How is data updated?
  • How often?
  • Where should Ppk value be extracted to?
mdeng
Hi Jarmo
I want to extract the Ppk values displayed in Process Capability or Process Screening using JMP's Ppk formula. The new data is updated to excel and/or in SQL database daily. I want values extracted to a JMP worksheet where I can graph Ppks using control charts.
Thanks
Margaret
Would you please describe in more detail, where the updates are coming from?
mdeng
Hi Jim,
Thanks
Margaret
