MYLEE
How can I change the order of overlaid graphs in graph builder
I'm new in JMP and I'm enjoying learning to use JMP/Graphbuilder.
I overlaid sub-group (3121B HP/3121B PHH/mic/Spheroid) to see time-dependant change. How can I change the order of overlaid graph? I tried to click sub-title, then I couldn't modify any (such as font). And also how can I change? It is for presentation use. Thanks in advance
Re: How can I change the order of overlaid graphs in graph builder
What you need to do, is to change the Value Order column property for your Drug column.
Go to your data table
Right click on the header for the Drug column and Select
Column Properties==>Value Order
You can then change the order to what you want, and then rerun your Graph Builder
Re: How can I change font of graphbuilder group box title in graph builder
As stated in my last response
"One of the font selections in
     File==>Preferences==>Fonts
is used for the Grouping text sizing. "
It turns out that the Font that it is using is the "Text" font
8 REPLIES 8
MYLEE
Thanks so much to help JMP beginner!- those function is quite hidden!
The way to keep from finding hidden functions, is to take the time to read the JMP Documentation. In particular, Discovering JMP and Using JMP. They are both found in the JMP Documentation Library
     Help==>JMP Documentation Library
These documents will really get you jump or rather JMP Started.
MYLEE
Still I have one problem is not solved- changing font in graphbuilder group box title (i.e. microsomes) (see below green highlight upper part). I tried to increase font size, then soooo difficult to find. I've tried to find also in JMP library document/help/tutorials, but no success. Is this only way to change the font using script?
MYLEE
Thanks- Jim,
Althought I tried, it didn't work...-not change the group title font (not working... ).  :(
MYLEE
@txnelson (Jim),
THANK YOU!  You are absolutely right, I've even thought 'TEXT' would be the title (of group). It would be great that it can be changed same way for legend.
Thank you again, you are so Super-helpful!
