MFVIT
How JMP determines resolution of fractorial designs
Hello dear All,
I was trying to figure out how JMP associates the resolution to blocked factorial or fractional factorial designs. JMP presents the resolution under the label 'Resolution - what is estimable' of the Screening design platform.
I will make two examples:
1) for a design with resolution VII, like the 2 to 7-1, JMP reports 5+. What is the meaning of the +? Does it mean that the resolution is actually higher than V?
2)  for a 2 to 4 run in two blocks JMP reports a resolution of 5+. What is the meaning of the + in this case?
Many thanks and have a fun weekend,
Marcello.
louv
Staff (Retired)
Re: How JMP determines resolution of fractorial designs
Hi Marcello,
In your first example 2**(7-1) there are 64 runs and thus you have enough degrees of freedom for 7 main effects, 21, 2-way interactions, and 35, 3-way interactions plus the intercept. If you utilize the Evaluate Design capability on that 64 run experiment you can specify what order interactions in the alias terms section and see that some 5-way interactions are aliased with main effects and some 5-way interactions are aliased with two-way interactions thus the 5+ number is indicated.
Lou
MFVIT
Hello Lou. Many thanks for your reply. Best, Marcello.
