Level XIII
Hover Label:more than one plot?
Is it possible to display more than one plot in the Hover Label?
I tried it by putting two plots into a H List Box, but noticed that
- the hover label just shows the first plot
- after clicking on the hover label, both plots show up, but the data filter is not applied to the second plot:
View more...
Graph Builder(
	Size( 401, 369 ),
	Graph Spacing( 4 ),
	Variables( X( :height ), Y( :weight ), color( :sex ) ),
	Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Set Graphlet(
				Picture(
					H List Box(
						Graph Builder(
							Lock Scales( 1 ),
							Variables( X( :sex ), Y( :age ), color(:sex) ),
							Elements( Heatmap( X, Y, Legend( 5 ) ) )
						Graph Builder(
							Variables( X( :sex ), Y( :height ), color(:sex) ),
							Elements( Bar( X, Y, Legend( 6 ) ) )
Level XIII
Re: Hover Label:more than one plot?
Ouch, yes.
So, the _whereExpr wasn't the actual problem
--> actual issue fixed via Substitute
View more...
local_whereExpr = Expr(
	:height == 61 & :weight == 128
); // for quick debugging
dt << Graph Builder(
	Size( 401, 369 ),
	Graph Spacing( 4 ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Set Graphlet(
				Picture(
					Show( Namespace( "local" ) << Get Contents() ); //contains :_whereExpr
					// New Window("test", //for quick debugging
					Eval(
						Substitute(
								Expr(
									H List Box(
										Graph Builder(
											Lock Scales( 1 ),
											Variables( X( :sex ), Y( :age ), Color( :sex ) ),
										Graph Builder(
											Lock Scales( 1 ),
											Elements( Heatmap( X, Y, Legend( 5 ) ) ),
											Local DataFilter(
												Close Outline( 1 ),
												Add Filter( columns( :height, :weight ), Where( __myWhereExpr1__ ), Where( __myWhereExpr2__ ) )
											SendToReport( // Needen for  Jmp 17
												Dispatch({},"sex",ScaleBox,{Format( "Best", 9 ), Min( -0.5 ), Max( 1.5 ), Inc( 1 ), Minor Ticks( 0 )}),
												Dispatch({},"age",ScaleBox,{Format( "Fixed Dec", 12, 0 ), Min( -0.5 ), Max( 5.5 ), Inc( 1 ), Minor Ticks( 0 )}
							Expr( __myWhereExpr1__ ), Arg( Name Expr( local:_whereExpr ), 1 ),
							Expr( __myWhereExpr2__ ), Arg( Name Expr( local:_whereExpr ), 2 ),
							Expr( __myWhereExpr__ ),
Might not be easily done (at least not with simple graphs, you can use pictures though). Hover labels do have quite good documentation in JMP Help site
Scripting Guide > Scripting Graphs > Hover Labels > Add Graphs or Images to Hover Labels Using Grap...
Graphlet Commands
A required script that adds a thumbnail of a graph or an image to the hover label.
Picture() is always executed in a Hover Label Execution Context derived from the current visual element. The first Picture Box (outside of a local data filter) found will be used to generate the displayed image.
More documentation Using JMP > JMP Reports > Customize Hover Labels in JMP Graphs
Level XIII
Hm, how to get access to the local:_whereExpr
I assume, a quite simple error, but I can't find it ...
View more...
Graph Builder(
	Size( 401, 369 ),
	Graph Spacing( 4 ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Set Graphlet(
				Picture(
				Show(local:_whereExpr); // empty ?!?
				Eval(Eval Expr(
					Data Filter Context Box(
						H List Box(
							Current Data Table() << DataFilter( Local, Add Filter( columns( :height, :weight ), Where( Expr(Name Expr(local:_whereExpr)) )
							Graph Builder(
								Lock Scales( 1 ),
								Graph Spacing( 4 ),
							Graph Builder(
								Lock Scales( 1 ),
								Graph Spacing( 4 ),
Most likely your _whereExpr is getting evaluated and returning missing value.
Level XIII
Ouch, yes.
View more...
	Size( 401, 369 ),
	Graph Spacing( 4 ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Set Graphlet(
				Picture(
					Eval(
						Substitute(
								Expr(
									H List Box(
										Graph Builder(
											Lock Scales( 1 ),
										Graph Builder(
											Lock Scales( 1 ),
											Local DataFilter(
												Close Outline( 1 ),
Level XIII
By the way:
I generated the second subplot directly including the data filter from the beginning.
The first subplot gets the DataFilter via the Hover Label Framework  - after being initialized without Data filter.
This reminds me of another topic:
https://community.jmp.com/t5/Discussions/speeding-up-heatmap-graphs/m-p/571277/highlight/true#M78103
And indeed, Jmp 16 and Jmp17 behave different here:
On Jmp16, the data filter is always added after the initialization of the graph - even if the data filter is part of the Graph Builder code.
Therefore, for both plots, the range is locked via Lock Scales( 1 ) to the full range -> both plots look the same.
On Jmp17, if the data filter is part of the GraphBuilder code (second graph), the data filter is added immediately.
Therefore the axis ranges of the second plot are restricted to the filtered data.
-> new: If needed, one has to specify the axis ranges manually.
Jmp 17:
Jmp 16
Level XIII
maybe, sometimes this is exactly what the user wants:
- show just one graph with the "hover" filter applied
- and when you click on it:
- open the same graph
- plus a second "static" graph - without a "hover" filter applied
If so, one could call this bug a feature.
In Graph-Builder-30-Second-Challenge @martindemel shows that one doesn't even need a surrounding H/V List Box.
