robot
Horizontal Radio Buttons
Is it possible to produce a horizontal list of Radio Buttons?  The script below will product a list of vertical Radio Buttons, but I am making a user-selection window that will have a long list of options, similar to the multiple-choice test example here​, and I think a horizontal list of Radio Buttons will be most efficient.  If necessary, I can probably use a Combo Box, but I think the Radio Buttons will be faster.
New Window( "Example",
       rb = Radio Box(
             {"single", "double", "triple"},
             Show( rb << Get() )
I am using JMP12, but I hope the solution will also be compatible with JMP10 and above.
Any ideas?
pmroz
Re: Horizontal Radio Buttons
You can use the GROUP method to combine radio boxes in a horizontal fashion.  Check this out:
Here's the code.  If you have many entries you could use an array for all of the radio boxes.
      panelbox("Make a selection for each question",
            lineup box(ncol(6),
                  textbox("1. "), rb1 = radio box("A"), rb2 = radio box("B"), rb3 = radio box("C"), rb4 = radio box("D"), rb5 = radio box("E"),
                  textbox("2. "), rb6 = radio box("A"), rb7 = radio box("B"), rb8 = radio box("C"), rb9 = radio box("D"), rb10 = radio box("E"),
                  textbox("3. "), rb11 = radio box("A"), rb12 = radio box("B"), rb13 = radio box("C"), rb14 = radio box("D"), rb15 = radio box("E"),
rb1 << group(rb2);
rb1 << group(rb3);
rb1 << group(rb4);
rb1 << group(rb5);
rb6 << group(rb7);
rb6 << group(rb8);
rb6 << group(rb9);
rb6 << group(rb10);
rb11 << group(rb12);
rb11 << group(rb13);
rb11 << group(rb14);
rb11 << group(rb15);
pmroz
            lineup box(ncol(6),
rb1 << group(rb2);
rb1 << group(rb3);
rb1 << group(rb4);
rb1 << group(rb5);
rb6 << group(rb7);
rb6 << group(rb8);
rb6 << group(rb9);
rb6 << group(rb10);
robot
Very cool.  Thanks PMroz.
robot
Hi PMroz,
Thanks for the grouping script.  It works great for a non-modal window.  My problem now is that if I make the window modal, it will no longer read the group functions after the window creation.  Do you have any ideas how to get around this?
       <<Modal,
       Panel Box( "Make a selection for each question",
             Lineup Box( N Col( 6 ),
                    Text Box( "1. " ),
                    rb1 = Radio Box( "A" ),
                    rb2 = Radio Box( "B" ),
                    rb3 = Radio Box( "C" ),
                    rb4 = Radio Box( "D" ),
                    rb5 = Radio Box( "E" ),
                    Text Box( "2. " ),
                    rb6 = Radio Box( "A" ),
                    rb7 = Radio Box( "B" ),
                    rb8 = Radio Box( "C" ),
                    rb9 = Radio Box( "D" ),
                    rb10 = Radio Box( "E" ),
                    Text Box( "3. " ),
                    rb11 = Radio Box( "A" ),
                    rb12 = Radio Box( "B" ),
                    rb13 = Radio Box( "C" ),
                    rb14 = Radio Box( "D" ),
                    rb15 = Radio Box( "E" ),
rb1 << group( rb2 );
rb1 << group( rb3 );
rb1 << group( rb4 );
rb1 << group( rb5 );
rb6 << group( rb7 );
rb6 << group( rb8 );
rb6 << group( rb9 );
rb6 << group( rb10 );
rb11 << group( rb12 );
rb11 << group( rb13 );
rb11 << group( rb14 );
rb11 << group( rb15 );
robot
Never mind.  I put the group functions inside the window and that solved the problem.  Thanks!
       <<Modal,
                    Text Box( "1. " ),
                    Text Box( "2. " ),
                    Text Box( "3. " ),
