rajesh
Homoscedasticity of data using Cochran C test in JMP
How to evaluate Homoscedasticity of data  by using Cochran C test in JMP?
Re: Homoscedasticity of data using Cochran C test in JMP
A quick way to check for a statistic or model is to select Help > Statistics Index. The items are listed alphabetically and you can jump to a group of items starting with a particular character by typing that character. Cochran's C test is not available.
The Wikipedia entry for Cochran's C Test shows that this computation is pretty straight-forward so you could compute it by hand or with a script.
Note that JMP provides other tests for homoscedasticity in the Oneway platform. Select Analyze > Fit Y by X. Assign your data columns to the Y and X roles and click OK. Click the red triangle and select Unequal Variances.
rajesh
Thanks, Followed the steps you mentioned but unable to see Unequal variance option by clicking red triangle. Please suggest.
