ben_ph
Hiding a menu item in JMP Standard only
I have an addin where I'd like to show a menu item only if JMP Pro is being used. Is there something I can include in my addin.jmpcust to do that?
Say I have this command in my addin.jmpcust:
<jm:command>
  <jm:name>PRO ONLY</jm:name>
  <jm:caption>Pro Only</jm:caption>
  <jm:action type="text">show("Do something that requires JMP PRO")</jm:action>
  <jm:icon type="none"></jm:icon>
</jm:command>
Right now I give a popup warning if this menu item is selected and JMPProductName()=="Standard".
Re: Hiding a menu item in JMP Standard only
You can create a startup script that will run and specify which addin.jmpcust to use, based upon finding what JMP Version is running.
jmpstart.jsl
jmpstart.jsl
ben_ph
Great suggestion. Thanks @txnelson !
