Benjamin_Fuerst
Hide x-axis and y-axis number label
Hello JMP community,
I am preparing my talk on the upcoming discovery summit.
Because of confidentiality reasons I cannot show the y and x-axis labels.
See pic, where I removed the axis box via the properties visibility option.
Normalizing all the data to range 0 to 1 changes all the analyses I did with scripts.
So as I see it, I need to keep the original (confidential) numbers but need to hide the Axis Box.
Can anybody assist me with a better idea than doing it manually in the properties or something totally different approach how to avoid showing confidential data?
Ideally there would be something like a column properties which suppresses the number showing on the axises in all analyses.
Appreciate a hint for an easier way to do this!
Ben
Re: Hide x-axis and y-axis number label
Here is a simple script that will hide the axis values for all windows in your session.  To make the axis values visible, change "hidden" to "visible" and rerun the script.
i = 1;
While( Window( i ) << get window title != {},
	Try( (Window( i ) << xpath( "//AxisBox" )) << visibility( hidden ) );
	i++;
ian_jmp
Level X
Depending on exactly what's needed, you can just suppress the numbers that appear on the axes too:
NamesDefaultToHere(1);
biv = dt << Bivariate(X(:height), Y(:weight));
Wait(2);
bivRep = Report(biv);
abs = bivRep << Xpath("//AxisBox");
abs << Show Major Labels( 0 );
9 REPLIES 9
i = 1;
	i++;
ian_jmp
Level X
Wait(2);
Benjamin_Fuerst
@txnelson @ian_jmp : Thanks a lot.
Actually a mixture of both of your answers did the thing, I needed at this point.
i= 1;
	Try( (Window( i ) << xpath( "//AxisBox" )) << Show Major Labels( 0 ) );
	i++;
For removing all the axis items of a profiler axis (except the title), I extended the script with this
i = 1;
	Try( (Window( i ) << xpath( "//TextBox" )) << visibility( hidden ) );
	i++;
i= 1;
	i++;
i= 1;
	Try( (Window( i ) << xpath( "//NumberEditBox" )) << visibility( hidden ) );
	i++;
One has to be cautious, since e.g. xpath( "//TextBox" ))  then attributes the visibility to all TextBoxes.
This removes other things one probably does not want to remove!
@Florian_Vogt @Emmanuel_Romeu : Since we discussed this, possible interesting to know this work around!
MELIU
HI Jim,
Thanks for sharing this with the community, I found it very useful!
Can you please help tell me how to modify the code so it only hides the values on the Y-axis ?
ML
ron_horne
Hi @Benjamin_Fuerst ,
I think @txnelson gave a good solution.
I was expecting to have this ability in the preferences but i didn't manage to see any difference with or without these options selected. Can anyone demonstrate the difference?
Benjamin_Fuerst
@ron_horne I could not see a difference having it ticked or not in the graphbuilder...
Hi @ron_horne ,
have you restarted JMP after changing the preference?
ron_horne
Hi @Florian_Vogt
i did restart, could you show me a picture of with and without these boxes checked?
so i know what to look for.
Hi @ron_horne ,
I was initially rather generally speaking - while I wanted to prepare the screenshots, I found out this is a bug which is already under construction and will be solved.
The correct way is, the boxes (that you have outlined by a box in your screenshot) are ticked as default. If you uncheck them and restart JMP, the graph builder will not show the axes.
Best
Florian
