Level XII
Hide Level from a plot
The Configure Levels menu provides a very elegant way to change the levels which are displayed in a plot. One can rename and combine levels.
Is there also an option to hide levels?
ron_horne
Re: Hide Level from a plot
Hi @hogi ,
if it is the first or last category you may be able to exclude it by changing the axis settings as such.
this can also be done manually with the grabber tool.
let us know if it works.
Hi @hogi ,
to my knowledge only by adding a local data filter:
Best
Florian
Level XII
Hm, the Data Filter will remove the corresponding rows from everywhere in the plot -  not just remove the label from one axis.
Names Default to Here(1);
Graph Builder(
	Variables( X( :height ), X( :sex ), Y( :weight ), Color( :sex ) ),
	Elements(
		Position( 1, 1 ),
		Points( X, Y, Legend( 24 ) ),
		Smoother( X, Y, Legend( 25 ) )
	Elements( Position( 2, 1 ), Points( X, Y, Legend( 26 ) ) ),
	Local Data Filter( Add Filter( columns( :sex ), Where( :sex == "F" ) ) )
ron_horne
Hi @hogi ,
Level XII
Hi @ron_horne . This is a nice workaround which will work for simple plots like here for Big Class.
Good, that I can make the level  "last" by adjusting the Levels settings
But the workaround is kind of fragile - the position will depend on the # of of labels in the current data set.
And it gets very difficult to count if multiple columns are used in a hierarchy on the Axis.
ron_horne
@hogi
another way would be to recode the categories into a new column. then you can group all the categories you want to hide and set them to be first or last.
hiding (not excluding) in general and of a category (not a row) is a bit questionable from an objective analytical perspective. that would be my guess as to why it is not easily available in the software.
Level XII
Yes, could be.
