Yotam
Help with searching in string
I have the following task to do.
Let's say I have 3 columns: A,B,C
Each cell in Col A is in the following format: 29;30;28;27;30; ...
So just random numbers separated by ;
Each cell in Col B is in the following format: 4;5;1;3;6; ...
So these are numbers in the range of 1-25 (without repeating) in a random order, separated by ;
Col C is a single number in the range of 1-25, for example 3.
For any given row Col A and Col B have the same number of terms between the ";" (doesn't have to be the same in different rows).
And now to the task: I want to create a new column D, which contains the value from Col A found in the location of Col C in Col B.
For example, if
Col A = 29;30;28;27;30
Col B = 4;5;1;3;6
Col C = 3
Then Col D = 27
Because 3 is found in the 4th location in Col B (after the 3rd ;), and in the same location in Col A you can find 27.
I hope I explained it clearly, would appreciate any help. Please see attached file for example (I computed Col D manually for the example).
Thanks
Re: Help with searching in string
Should be fairly simple by using Words() and Contains().
Num(Words(:A, ";")[Contains(Words(:B, ";"), Char(:C))]);
See scripting index for more examples about those functions
Yotam
Thank you!
Here is one way to do it
theList = Words( :B, ";" );
location = Contains( theList, Char( :C ) );
Show( theList, location );
Try( Num( Word( location, :A, ";" ) ), . );
