JB-2
Issue defining cell value as variable
I want to use values from one datatable as reference lines on a Variability plot based on a separate datatable. My current code is below, it hopefully makes sense as shared. I am using JMP 15.2
My issue is that when I run all of this at once, I do not get any reference lines on my plot.
However, if I first run only the section before '//SPLIT POINT' and then separately run the section after '//SPLINT POINT', it works without issue (reference lines are visible on my plot).
A final point is that if I use
Target = dt1_spec_limits::Name( "data_column_A" )[1]
instead of
Target = dt1_spec_limits:Name("Graph_Target_line")[1]
the reference line shows on the plot, even when the whole script is run as one. So I think it is something to do with the calculations updating in the datatable?
Any insights would be greatly appreciated, thanks.
//join two datatables to create table of spec limits
dt1_spec_limits = dt1_mean_join <<
Join(
With( dt1_std_join ),
By Matching Columns( :Join = :Join ),
Drop multiples( 0, 0 ),
Include Nonmatches( 0, 0 ),
Preserve main table order( 1 )
//calculate the Target, USL and LSL values
New Column( "Graph_Target_line",
Numeric,
"Continuous",
Format( "Best", 6 ),
Formula( :Name( "data_column_A" ) )
New Column( "Graph_USL",
Numeric,
"Continuous",
Formula(
:Name( "data_column_A" ) + 3.15 *
:Name( "data_column_B" )
New Column( "Graph_LSL",
Numeric,
"Continuous",
Formula(
:Name( "data_column_A" ) - 3.15 *
//SPLIT POINT
//assign the variables to be used in the Variability plot
USL = dt1_spec_limits :Name("Graph_USL")[1]
LSL = dt1_spec_limits:Name("Graph_LSL")[1]
//Plot based on data from one table with the reference lines based on above
Current data table(dt1_plotting_data)
Variability Chart(
Y( :Name( "column_1" ) ),
X( :Equipment, :Date, :Time ),
Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
Std Dev Chart( 0 ),
Dispatch(
{"Variability Chart for column_1"},
"2",
ScaleBox,
Add Ref Line( 0, "Dotted", "Medium Light Gray", "", 1 ),
Add Ref Line( Target, "Solid", "Medium Dark Green", "Target", 1 ),
Add Ref Line( USL, "Solid", "Medium Dark Red", "USL", 1 ),
Add Ref Line( LSL, "Solid", "Medium Dark Red", "LSL", 1 )}
Dispatch(
"Variability Chart",
FrameBox,
{Row Legend(
Tool_MM,
Color( 1 ),
Color Theme( "JMP Default" ),
Marker( 0 ),
Marker Theme( "" ),
Continuous Scale( 0 ),
Reverse Scale( 0 ),
Excluded Rows( 0 )
Re: Issue defining cell value as variable
I suspect that your dt1_spec_limits data table is not completed before the Variability Chart is run.  Try adding
Wait( 0 );
just before the // SPLIT POINT.
Wait( 0 );
JB-2
Thanks very much
