dfusco923
Help with Graph Builder - Would like a Background Color other than White
Hello - I would like to add a background color to a JMP chart that I built in JMP Graph Builer.  I save the chart as a PNG and have attached it.  Does anyone know how to do this?
ThuongLe
Re: Help with Graph Builder - Would like a Background Color other than White
Go to File --> Preferences --> Styles and select the color you want :)
Thuong Le
You should be able to go to
     Edit=>Properties
and then click on the area of interest and change the background color
But for JMP 15, changing the background color of the Frame Box() using this method, does not work.  It appears to have been fixed in JMP 16.
However, through scripting, you can use the
    << background color( ??? )
to get the results you want
gb = Graph Builder(
	Size( 528, 456 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements(
		Points( X, Y, Legend( 3 ) ),
		Smoother( X, Y, Legend( 4 ) )
Report( gb )[FrameBox( 1 )] << background color( red );
and change the color
Georg
In my JMP 15.1.0 (win10) in GB I can Change Background Color via context menu interactively.
Georg
Excellent.........
