ClaireatBH
Help on script to import multiple TXT files and removing certain data JMP 15
I would like to import a number of TXT files into one data table.
An individual TXT file looks like this and I would like to only import the highlighted data and if possible create a new column to capture the batch number.
I’ve written the following script (below) which gets me partially there but I still have to delete some of the data as highlighted below. This is ok when I only have a few files but when there are more than 10 it’s a problem.
Can anyone recommend an addition to the script to resolve this issue? I'm currently using JMP 15.
Thank you!
Multiple File Import(
	<<Set Folder(
		"C:\folder"
	<<Set Show Hidden( 0 ),
	<<Set Subfolders( 0 ),
	<<Set Name Filter( "*.txt; " ),
	<<Set Name Enable( 1 ),
	<<Set Size Filter( {3334, 3334} ),
	<<Set Size Enable( 0 ),
	<<Set Date Filter( {3694079995.454, 3694079995.454} ),
	<<Set Date Enable( 0 ),
	<<Set Add File Name Column( 1 ),
	<<Set Add File Size Column( 0 ),
	<<Set Add File Date Column( 0 ),
	<<Set Import Mode( "CSVData" ),
	<<Set Charset( "Best Guess" ),
	<<Set Stack Mode( "Stack Similar" ),
	<<Set CSV Has Headers( 1 ),
	<<Set CSV Allow Numeric( 1 ),
	<<Set CSV First Header Line( 1 ),
	<<Set CSV Number Of Header Lines( 1 ),
	<<Set CSV First Data Line( 4 ),
	<<Set CSV EOF Comma( 1 ),
	<<Set CSV EOF Tab( 0 ),
	<<Set CSV EOF Space( 0 ),
	<<Set CSV EOF Spaces( 1 ),
	<<Set CSV EOF Other( "" ),
	<<Set CSV EOL CRLF( 1 ),
	<<Set CSV EOL CR( 1 ),
	<<Set CSV EOL LF( 1 ),
	<<Set CSV EOL Semicolon( 0 ),
	<<Set CSV EOL Other( "" ),
	<<Set CSV Quote( "\!"" ),
	<<Set CSV Escape( "" ),
	<<Set XML Method( "guess" ),
	<<Set XML Guess( "huge" ),
	<<Set XML Settings( XML Settings() ),
	<<Set JSON Method( "guess" ),
	<<Set JSON Guess( "huge" ),
	<<Set JSON Settings( JSON Settings() ),
	<<Set Import Callback( Empty() )
) << Import Data
Re: Help on script to import multiple TXT files and removing certain data JMP 15
Hi @ClaireatBH,
In addition to your Multiple File Import code, the JSL below should do the trick. It was mostly put together with the enhanced log in JMP 16, just released yesterday.
Kind Regards,
Ben
// Setup and point to open data table
Names Default to Here(1);
// Highlight Batch# rows
dt << Select Where( :Column 1 == "Batch#" );
// Make a subset of Batch# rows
dt_batch = dt << Subset( Output Table( "Batch Numbers" ), Selected Rows( 1 ), selected columns( 0 ) );
// Change name in subset so doesn't overwrite when joined back onto
dt_batch:Time << Set Name("Batch No");
// Delete unwanted rows
dt << Select Where( Is Missing( :V 2 ) ) << Delete Rows;
// Pull Batch No into main table
dt << Update(
	With( dt_batch ),
	Match Columns( :File Name = :File Name ),
	Add Columns from Update Table( :Batch No ),
	Replace Columns in Main Table( None )
// Close subset with Batch No
Close(dt_batch, nosave)
// Move selected column: Batch No
Data Table( "SAS_TEST_FILE_FROM_1_SAS_TEST_FILE_FROM_3" ) <<
Move Selected Columns( {:Batch No}, after( :Column 1 ) );
// Delete column: Column 1
Delete Columns( :Column 1 );
ClaireatBH
@benfrancis That works perfectly. Thank you for your help!
kendy
NA
@kendy  Here is a script that should convert your Measure column to separate columns for each parameter
// Create a new column to hold the parameter name
dt << New Column( "Parameter",
	character,
	set each value(
		If( Left( :col1, 1 ) == "[",
			temp = Word( 1, :col1, "[]" );
		temp;
// Find all measurement rows and subset them to a new table
dt << select where(isMissing(Num(:col2))==0);
dtMeasures = dt << subset( selected rows(1), selected columns(0));
// Convert the Measure data to numeric
dtMeasures:col4 << datatype(numeric)<<modelingtype(continuous);
// Split the table to create the new measurement table
dtFinal = dtMeasures << Split(
	Split By( :Parameter ),
	Split( :col4 ),
	Output Table( "Final" ),
	Remaining Columns( Drop All ),
	Sort by Column Property
// Cleanup
close( dtMeasures, nosave );
dt << delete columns(Parameter);
kendy
Hi Jim,
I am guessing that there is a blank character in front of the [D105_Unf25].  The below script should fix that
	character,
	set each value(
		If( Left( trim(:col1), 1 ) == "[",
			temp = Word( 1, trim(:col1), "[]" );
		temp;
	Split( :col4 ),
// Cleanup
