Help for Some Sort of Nested Design
Hello!
JMP newbie here.
I am working on a project where I need to come up with some sort of nested DOE design for some variables I want to test. I work in the proteomics industry and need to run an effects model of common med tech errors. We run our samples in batches of 96. There are some variables I need to test on the individual sample level (Like a reagent level differs for that sample), and others I need to test on the batch level (Like there are temperature fluctuations for this batch).
Does anyone know how I could set this kind of thing up in JMP?
Thanks for any help or resources!
Victor_G
Re: Help for Some Sort of Nested Design
Hi @PowerJackal4255,
Welcome in the Community !
I think a Split-Plot design may be relevant for your needs. Split-Plot designs are designs where the randomization is restricted because of the presence of "Hard to change" factors. These factors are not randomly reset between each runs, but are changed from "whole plot" to "whole plot".
In your situation, factors tested on the individual sample level will be "Easy to change" factors, as their levels can be reset and changed randomly without restriction. Factors tested on the batch level will be "Hard to change" factors, as their levels are reset only at each new batch of 96 runs.
Here is how you can create this type of design with the Custom design platform (simple example here inspired from your use case):
  1. Define your factors, and click on "Changes" next to each factor to change its randomization (depending if it's applied on batch (hard) or individual (easy) level) :
    Note that you can have several Hard to change factors. If you have several ones, you have the possibility to make them vary independantly from whole plot to whole plot, or not.
  2. Then, you can add any constraints, and specify the assumed model you want to fit, as well as determining the number of whole plots (= number of batch in your example), as well as the total number of runs. In this example, since your samples are run in batch of 96, I defined 4 batches (whole plots) of 96 samples, so I defined 384 as my total number of runs :
  3. Click "Make Design" to create your design. You can check that your design enable to have only one value for the hard to change factor for each whole plot :
You can read the documentation to see how to create and analyze such design here : Split-Plot Experiment
Some other ressources to help you:
Hope this answer will help you,
Victor GUILLER
7 REPLIES 7
Victor_G
Victor GUILLER
How do I generate the graph you showed to check if there is only one hard to change value per plot? Thanks for your response!
Victor_G
There might be several ways to show the structure of your Split-Plot design.
In the specific example shown in my previous response, I used Graph Builder and :
  • Place one of the "Easy to change" factor (here Catalyst) as X variable
  • Place the other "Easy to change" factor (here Reagant (%)) as Y variable
  • Place "Whole Plots" in the "Wrap" zone (to display the repartition of factors for each plate)
  • Place the "Hard to change" factor (here Temperature) in the "Color" zone.
This enable to show that Temperature can't be changed inside a whole plot (due to the restriction randomization of this "hard to change" factor), but it can be changed between whole plots. I'm sure there are other clever ways to display this Split-plot design structure.
Best would be to use some kind of tree plot, to display the temperature/whole plot association, followed by complete randomization of the other two factors. These are called Factor Relationships Diagrams, and I really like the introduction proposed by Anthony Welsh in one of his post : intro-scenario-to-factor-relationship-diagrams
Concerning nested factors in DoE, there are several discussions in the Community on this topic :
DOE for Nested Factors
Nested DOE with continous factors?
Using disallowed combinations to remove a factor from the DoE
Victor GUILLER
statman
Really hard to tell from your overly simple description of the situation.  In fact, it sounds like a nested sampling study vs. a DOE. If, however, you have factors that will be at different levels depending on other factors, for example, this is indeed a nested situation.  The key to handling nested variables is less in setup and more in analysis when you write the model.
Can you provide resources describing a nested sampling study?
statman
Start here:
SANDERS, R. D., LEITNAKER, M. G., & SANDERS, D. (1994). THE ANALYTIC EXAMINATION OF TIME-DEPENDENT VARIANCE COMPONENTS. Quality Engineering, 7(2), 315–336. https://doi.org/10.1080/08982119408918786
DonnyKopp
@PowerJackal4255 please join us on the 23rd for our quarterly DOE Club and submit a question to be addressed live. It would be great to see you there. Here's the link: DOE Club Q3 | JMP
