In Graph Builder, there is a special color ("Missing"), which is used if the entry of the color column is empty in the respective row.
Very convenient.
This functionality is enabled for Points, Bar, Heatmap and Treemap plots, if a column with modeling type ordinal or nominal is used.
This functionality is enabled for Points, Bar, and Treemap plots, if a column with modeling type continuous is used.
On the other hand, this functionality is not enabled by default for Heatmap plots if a column with modeling type continuous is used.
What do I have to do to enable it?
top part: Points (points with "missing" color)
bottom part: Heatmap (tiles with "missing" color are missing)
➥ Tiny-Traps-in-Jmp-and-JSL
Names Default to Here(1);
dt << New Column( "one",<<Set Each Value( 1 ) );
dt:age[5::20]=.;
Graph Builder(
Variables( X( :name ), Y( :one ), Y( :one ), Color( :age ) ),
Elements(
Position( 1, 1 ),
Points( X, Y, Legend( 12 ), Jitter( "None" ) )
Elements( Position( 1, 2 ), Heatmap( X, Y, Legend( 7 ) ) ),
Dispatch(
"Graph Builder",
FrameBox,
{Marker Size( 20 ), Marker Drawing Mode( "Normal" )}
wait(2);
dt:age << Set Modeling Type( "Continuous" );
