Hi thomasd,
It sounds like you're running a hierarchical cluster analysis, is that right? For that analysis output the rows are rearranged to form the dendrogram, so we'll need to do something else to form the graphic I think you want. If you're looking to preserve your row ordering and show lipidomic concentration in a heat map, perhaps Graph > Cell Plot will work for you.
Here's a simple example with the Big Class sample data set:
![8185_Screen Shot 2015-03-01 at 12.40.51 AM.png 8185_Screen Shot 2015-03-01 at 12.40.51 AM.png](https://community.jmp.com/t5/image/serverpage/image-id/1306i72CA0A7820876FC5/image-size/medium?v=v2&px=400)
![8192_Screen Shot 2015-03-01 at 12.40.58 AM.png 8192_Screen Shot 2015-03-01 at 12.40.58 AM.png](https://community.jmp.com/t5/image/serverpage/image-id/1307i7C7681C85154FFEF/image-size/medium?v=v2&px=400)
And here is a bigger example using the Blood Pressure sample dataset, with 4 levels of the experimental factor, and 6 DVs:
![8194_Screen Shot 2015-03-01 at 12.58.23 AM.png 8194_Screen Shot 2015-03-01 at 12.58.23 AM.png](https://community.jmp.com/t5/image/serverpage/image-id/1308iF5C602F50B029ABB/image-size/medium?v=v2&px=400)
![8193_Screen Shot 2015-03-01 at 12.56.52 AM.png 8193_Screen Shot 2015-03-01 at 12.56.52 AM.png](https://community.jmp.com/t5/image/serverpage/image-id/1309i270AC7AC99F09851/image-size/medium?v=v2&px=400)
Does that get close to what you're looking for? If not, can you provide an image of the kind of plot you're looking to make? I'm sure we can find a way to make it with JMP.
Hope this helps!
julian
