Hazard Ratio in the Fit Proportional Hazards Platform?
Jul 22, 2016 11:58 AM(12903 views)
The Fit Proportional Hazards Platform does not provide a result denoted as Hazard Ratio but it provides Risk Ratios for categorical variables. I would appreciate if someone in the community could confirm for sure that the risk ratio in this procedure is equivalent to the usual hazard ratio.
