bharathu
Having custom date range in SQL based on user input variable
I am having issues while trying to have a custom user input based variable into my SQL code. The problem with the database I am connecting is that the date column is character. So here is the actual code that works well with hard coded dates inside the SQL query.
Open Database("Generic database connection string",
" SELECT
p.productname,
p.model,
p.family,
TO_DATE (SUBSTR (txntime, 1, 15), 'yyyy/mm/dd hh24miss') txntime
FROM database p
WHERE
txntime >= '20161201 000000000'
AND txntime < '20161231 000000000'
// End of SQL statement
"New_Table" // New table name
The picture below shows the sample view on how the dates are saved in this table. Column property is Character & Nominal.
Here is the code I tried to insert user input variable. This code returns an empty table.
Delete Symbols();
Delete Globals();
nw = new window("Scrap Data", << modal(),
    panelbox("Enter Date Range",
       hlistbox(
            text box("From Date"),
            fromdate_teb = text edit box("%", << set width (100)),
        hlistbox(
            text box("To Date"),
            todate_teb = text edit box("%" , << set width (100)),
    panelbox("Actions",
        hlistbox(
            ok_button = button box("OK",
                        fromdate = fromdate_teb  << get text;
                        todate = todate_teb << get text;
                        ok_pushed = 1;),
            cancel_button = button box("Cancel", ok_pushed = 0),
      " SELECT
       p.productname,
       p.model,
       p.family,
  FROM database p
WHERE
       txntime >= '^fromdate^'
       AND txntime < '^todate^'
"New_Table" // New table name --> can be changed as per requirements
12 REPLIES 12
bharathu
Re: Having custom date range in SQL based on user input variable
Is there a way to have same user input fromt he text box work on another database SQL pull within the same script? The only catch is this new database follows traditional/standard numeric type date column. Is there a way to convert the user inputs (fromdate & todate) to secondarly variables with a numeric format month-day-year? Primary character based dates to be used for the issue that is already solved and secondary set to extract data based on numeric dates.
Here is my SQL that I am trying to use for extracting yield data from another database.
nw = new window("New Window for user input", << modal(),
       lineup box(ncol(2),
            text box("From Date: "),
            fromdate_teb = text edit box(format(today(),"y/m/d h:m:s"), << set width (150)),
            text box("To Date: "),
            todate_teb = text edit box(format(today(),"y/m/d h:m:s") , << set width (150)),
    panelbox("Actions",
        hlistbox(
                        fromdate = fromdate_teb  << get text();
                        todate = todate_teb << get text();
                        ok_pushed = 1;),
print(fromdate, todate);
Yieldsql = evalinsert(
" SELECT
        model,
        lot,
        wafer,
        COUNT(test_status_code) as BIN_COUNT
    FROM
        test_data
    WHERE
        purpose='PROD'
        AND test_data.test_date BETWEEN TO_DATE('^fromdate^', 'MM/DD/YYYY hh24:mi:ss') AND TO_DATE('^todate^', 'MM/DD/YYYY hh24:mi:ss')
    ORDER by lot, wafer");
dt = Open Database(	"Generic database connection string", Yieldsql, "Yield_Data");
bharathu
Fixed it by correcting the WHERE clause for test_date
AND test_data.test_date BETWEEN TO_DATE('^fromdate^', 'YYYY/MM/DD hh:mi:ss am') AND TO_DATE('^todate^', 'YYYY/MM/DD hh:mi:ss am')
Now I am able to use the same input date variables across 2 databases in the same query. One query pulls data with numeric dates and another sql pulls data where dates are character based.
Bandfield
Thank you for the assistance. This worked perfectly!
