jofu
HELP!? How to add sample size and % above USL and below LSL in graph builder?
I have plotted 2 data sets in graph builder that looks like this:
The USL and LSL were automatically placed via the spec limits I set in the column properties and adding refrences lines to graph. I then additionally added a Marginal USL (MUSL) manually in graph builder.
To this graph, I would like to add a label or note with the count/sample size for each data set as well as the % of points above USL, above MUSL and below LSL. I would like this "label" to be automatically updated everytime i change the data. How can I do this?
Jeff_Perkinson
Re: HELP!? How to add sample size and % above USL and below LSL in graph builder?
@jofu, it looks like your image didn't get attached properly.
Be sure to use the SafariScreenSnapz386.pngbutton in the toolbar in the editor to embed your image.
-Jeff
jofu
cwillden
Hi @jofu,
Welcome to the community!
The embedded image in your post is not showing, so I'm flying a little blind here. I'm guessing you can probably do what you want using Add Text Annotation. Here's an example:
dt = Open("$Sample_Data/Big Class.jmp");
USL = 68;
LSL = 55;
MUSL = 67;
SampleSize = N Row(dt << Get Rows Where(:Sex == "M"));
AboveUSL = Round(100*N Row(dt << Get Rows Where(:Sex == "M" & :height > USL))/SampleSize,2);
BelowLSL = Round(100*N Row(dt << Get Rows Where(:Sex == "M" & :height < LSL))/SampleSize,2);
AboveMUSL = Round(100*N Row(dt << Get Rows Where(:Sex == "M" & :height > MUSL))/SampleSize,2);
text_str = Eval Insert(
"Male Data
Sample Size: ^SampleSize^
Above USL: ^Above USL^%
Above MUSL: ^AboveMUSL^%
Below USL: ^BelowLSL^%"
gb = dt << Graph Builder(
	Size( 518, 452 ),
	Variables( X( :height ), Y( :sex ) ),
	Elements( Histogram( X, Y, Legend( 6 ) ) ),
) << Report;
gb << Add Text Annotation(
	Text(text_str),
	Text Box( {80, 60, 127, 281} )
And here's what that looks like:Annotate.PNG
You'll have to play with coordinates for the text box a bit.  I only worked with the first 2 to get the annotation approximately where I wanted.  You could do this in some kind of loop.  My concern with this approach is that the placement of the annotation is not very robust.  It would be nice if you could pin it to a corner of plot or something.
-- Cameron Willden
You can "Add Graphics Script" to the graph, where you can perform your calculations and display the results in most any format you desire.  Here is a sample
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
dt:height << set property(
	"spec limits",
	{LSL( 55 ), USL( 65 ), Show Limits( 1 )}
gb = Graph Builder(
	Size( 534, 448 ),
	Variables( X( :sex ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 5 ) ) ),
		Dispatch(
			"height",
			ScaleBox,
			{Add Ref Line( 58, "Solid", "Black", "MUSL", 1 )}
Report( gb )[FrameBox( 1 )] << Add Graphics Script(
