lou
lou
How do I use JSL to change the value in cells with missing values to zero?
When splitting a table, I end up with cells in multiple columns with missing values.  I want to change these values to 0.  The number of rows and split columns will vary, based upon data being pulled in through an SQL query.  How do I iterate through these selected columns and make this change from missing value to 0.
Thanks
thomasz
Re: How do I use JSL to change the value in cells with missing values to zero?
You can do it in three steps by hand:
Select the columns
Choose standardize attributes and then recode.
Recode all .'s to 0.
If you want to do it by jsl, you could do it like this:
dt=current data table();
colnames = dt << get column names( numeric,string );
For( i = 1, i <= N Items( colnames ), i++,
	column(dt,colnames[i])[dt<<get rows where(is missing(as column(dt,colnames[i])))]=0;
Kind regards, Thomas
cwillden
Try something like this:
dt = Current Data Table();
cols = dt << Get Selected Columns();
For( i = 1, i <= N Items( cols ), i++,
	Eval( Parse( Eval Insert( "^cols[i]^[dt << Get Rows Where(Is Missing(^cols[i]^))] = 0" ) ) )
I ended up using the Eval-Parse-Eval Insert because the Is Missing function was not liking something like Is Missing(cols[i]) or Is Missing(Column(cols[i])).  Using the Eval-Parse-Eval Insert always feels a bit like a hack, but it will get you what you need.
-- Cameron Willden
Here is the same idea as @cwillden but without having to use Eval(Parse())
numericColumnNames = dt << get column names( numeric, string );
For( i = 1, i <= N Items( numericColumnNames ), i++,
	Try(
		Column( dt, numericColumnNames[i] )[dt << get rows where(
			Is Missing( (As Column( dt, numericColumnNames[i] )) )
		)] = 0
David_Burnham
Agreed that in this instance it's not necessary but it's a tremendously useful pattern.  Take an arbitrarily complex piece of JSL.  Particularly one where it's difficult to parameterise the constituent components.  Bracket your variables with carets (^var^) and paste the whole lot inside an "Eval-Parse-Eval Insert" pattern.  Problem solved.
-Dave
thomasz
Select the columns
lou
lou
Thanks, thomasz.  Works great!!
