@txnelson, I completely flaked on that and forgot that Col Rank chooses the lowest as number 1!  With a small edit, it works as it should.  Thanks for catching that.  Being hasty leads to mistakes.
Graph Builder(
	Transform Column(
		"Transform[POURCENTAGE]",
		Formula( Col Rank( 0 - :POURCENTAGE, :QUARTER ) )
	Size( 731, 464 ),
	Variables(
		X( :QUARTER ),
		X(
			:ITEM,
			Position( 1 ),
			Order By( :POURCENTAGE, Descending, Order Statistic( "Mean" ) )
		Y( :POURCENTAGE ),
		Color( :ITEM )
	Elements(
		Bar(
			X( 1 ),
			X( 2 ),
			Y,
			Legend( 14 ),
			Summary Statistic( "Sum" ),
			Label( "Label by Value" )
	Local Data Filter(
		Add Filter(
			columns( :"Transform[POURCENTAGE]"n ),
			Where( :"Transform[POURCENTAGE]"n <= 3 )
