lala
Level IX
How to use JSL to determine whether a column has event handlers?
:height << Add Column Properties(
	Set Property(
		"Event Handler",
		Event Handler( Click( JSL Quote(Function( {thisTable, thisColumn, iRow}, {},  ab=(dt<<get selected rows)[1]; );) ) )
Thanks Experts!
mmarchandFSLR
Re: How to use JSL to determine whether a column has event handlers?
Names Default to Here( 1 );
has_handler =  !Is Empty( dt:height << Get Property( "Event Handler" ) );
lala
Level IX
回复: How to use JSL to determine whether a column has event handlers?
dt = Current Data Table();
col = Column(dt, "height");
colScript = col << Get Script;
mmarchandFSLR
