Thierry_S
GraphBuilder > FrameBox << Add Graphics Script (V Line (x,y1,y2)): dynamically assign x, y1, and y2?
Hi JMP Community,
It's my turn to be stumped by an apparently trivial project.
I'm trying to dynamically add V Lines to a Graph Builder plot and I'm getting rather unexpected results with the test script below:
Names Default to Here (1);
dt = New Table ("TEST",
	New Column ("X", Set Values ([1,2,3,4,5])),
	New Column ("Y", Set Values ([3,2,5,8,6]))
gb = dt << Graph Builder(
			Fit to Window( "Off" ),
			Level Frame Color( "Medium Dark Gray" ),
			Level Spacing Color( "Medium Dark Gray" ),
			Level Underline( 1 ),
			Page Level Underline( 0 ),
			Spacing Borders( 1 ),
			Variables( X( :X ), Y( :Y ) ),
			Elements( Points( X, Y, Legend( 5 ) ) )
gbr = gb << report;
Ypos1 = 2;
Ypos2 = 6;
For (i = 1, i<=5, i++,
				Xpos = i;
				gbr [Framebox (1)] << Add graphics Script (
					Pen color (Green);
					V Line (1,4,6);
					Pen color (Red);
					V Line (Xpos, Ypos1, Ypos2);
					Pen color (blue);
					V Line (i, 6,8);
I get the green V Line correctly placed, I get one red V Line positioned at X = 5, and no blue line.
I tried adding Eval Expr (Expr()) for the entire expression and within the graphic script without success, so I'm sure that there is a simple solution that is escaping me at this late hour.
Any help would be greatly appreciated.
Thanks,
TS
Thierry R. Sornasse
Re: GraphBuilder > FrameBox << Add Graphics Script (V Line (x,y1,y2)): dynamically assign x, y1, and y2?
I seem to be able to get blue lines with eval(evalexpr(:
Eval(EvalExpr(gbr [Framebox (1)] << Add graphics Script (
	Pen color (Green);
	V Line (1,4,6);
	Pen color (Red);
	Pen color (Blue);
	V Line (Expr(i), 6,8);
Using JMP15.2.1
pauldeen
				Xpos = i;
					Pen color (Green);
					V Line (1,4,6);
					Pen color (Red);
					V Line (expr(Xpos), expr(Ypos1), expr(Ypos2));
					Pen color (blue);
					V Line (expr(i), 6,8);
	Pen color (Green);
	V Line (1,4,6);
	Pen color (Red);
	Pen color (Blue);
Using JMP15.2.1
pauldeen
				Xpos = i;
					Pen color (Green);
					V Line (1,4,6);
					Pen color (Red);
					Pen color (blue);
