wr
wr
Graph builder x-axis on top and bottom
In a vertically stacked set of graphs (created using graph builder) is there a way to script x-axes to all the graphs? I have ~15 graphs one above the other and only one x-axis at the very bottom.
Thank you!!
XanGregg
Re: Graph builder x-axis on top and bottom
In JMP 12, you can use the Page role to get repeated axes. Or using the By role from the launch dialog. In earlier versions of JMP, you can use the By role via scripting only.
