EricTsai
Graph builder overlay setting
Dear all,
I would like to know if I can assign color to specific data range in graph builder?
for example ( please refer to attached photo) , the default color blue is assigned to data ranging from 0.128~0.193 ,so can i change to 0.128~0.228 ?擷取.PNG擷取.PNG
Re: Graph builder overlay setting
I had previously posted a solution, but it was based on an unreleased feature-in-progress for a future release.  I do not believe the levels can be customized in JMP 15 or earlier.  Sorry for the confusion.
Since I have to retract the original suggestion, perhaps a workaround would be useful.  I would suggest creating a formula column to create the desired overlay categories.  For example:
EricTsai
thanks a lot for ur reponse~!! it works
EricTsai
hi , but I don't have custom levels option
EricTsai
thanks, it helps , but what if I have multiple columns to modify~?
when will the custom levels be released?
