Abby_Collins14
Graph builder: Saving y-axis scale and ref lines while using column switcher
I am making plots in graph builder that look at how observations look relative to limits. I have rescaled the y-axis and would like to add reference lines too. I do this and looks good. However when I add the column switcher to go through different observations the rescaled y-axis and ref lines disappear. Does anyone know how I would get them to stay while using column switcher to loop through observations? see images below of the rescaling happening with column switcher
Level XIII
Re: Graph builder: Saving y-axis scale and ref lines while using column switcher
you could adjust the axis scales + add reference lines
... and save the settings as column properties to each of the columns:
Abby_Collins14
Thanks! I tried this but unfortunately it doesn't work because my two limits columns are using Link ID to another data set. The reason being that my x-axis is time points and the current data set has many more time points than limits per time point
Depending on your data: graphic script, reference lines or stacking data and + local data filter are usually good options.
Byron_JMP
I end up setting the axis properties too.
If you revert axis settings (right click on y axis) then it should go back to auto scaling.
I feel like an add-in that sets axis min and max based on some range* of the spec limits might be useful - anyone have that handy?
*something like axis max/min = LSL +/- 10% of spec range.
shampton82
Level VIII
Hey @Abby_Collins14 ,
Have you tried selecting this?
