Clanlope
[Graph builder] Batch pin the hover label for selected rows
Dear all,
Currently I use JMP16 to create a graph.
I have a col with picture in it, and I want to pin the picture for each dot I selected so I turn on the "add label" of this col.
But I find that I can only by hover my pointer on the dot, and wait the hover label shown itself, and then click the pin button to pin it one by one,
is there any faster way to achieve this like jsl code?  I have million of rows need to show out the pics.
thanks!
22 REPLIES 22
Re: [Graph builder] Batch pin the hover label for selected rows
I would drop the excluded rows already from selrows
selrows = dt << Get Rows Where(Selected() & !Excluded())
Clanlope
Oh I see the issue now: hiding or excluding rows causes an index mismatch for the remaining data.
gb = dt << Graph Builder(Variables(X(:age), Y(:height)), Elements(Points(X, Y, Legend(3))));
dt << Select Rows([1, 10, 16, 20, 30]);
ms = Report(gb)[framebox(1)] << Find Seg(Marker Seg(1));
selrows = dt << Get Selected Rows();
pin_expr = {};
For Each({v}, selrows,
	coord = ms << Get Point(v);
	Show(coord);
	Insert Into(
		pin_expr,
		Eval(
			Eval Expr(
				{Add Pin Annotation(
					Seg( Marker Seg( 1 ) ),
					Index Row( Expr( v - 1 ) ),
					Origin( Expr(coord)),
					UniqueID( Expr( v - 1 ) )
Eval(
	Substitute(
			Expr( Report(gb)[framebox(1)] << __pin_expr__ ),
		Expr( __pin_expr__ ), Name Expr( pin_expr )
By using this code, when row 17 hidden/excluded, it will cause the annotations of rows 20/30 to shift to the wrong positions.
Is there a way to prevent this from happening? I mean for sure I have data points to be excluded.
Clanlope
Bad news if the graph builder has local data filter the index is mismatched.
Is there a way to deal with  graphs with local filter active?
You can get the rows which local data filter will show by sending message
<< Get Filtered Rows;
to the local data filter
Clanlope
Thanks for your help! I am almost there!
By the way, is there a way to batch remove the annotation added by the scripts?
gb << SendToReport( Dispatch( {}, "Graph Builder", FrameBox(__which__), __pin_expr__ ) )
If you can get references to all of those, I think you could set << Close or << Delete message to the list to remove them all at the same time. You might also want to utilize << inval before deletion and << update window after.
Clanlope
My code is designed for an existing graph builder obtained by gb = (Current Report() << Find( "Graph Builder" )) << Get Scriptable Object;
then I created an Eval loop as mmarchandFSLR's way:
it looks like I can only get access to the gb itself, but nowhere to define the Add Pin Annotation list from the code below:
is there a way to read the Unique ID or something of each one and assign << delete to it then?
pin_expr = {};
For Each( {v, i}, dt << Get Selected Rows,
	Insert Into(
		pin_expr,
		Eval(
			Eval Expr(
					Index( Expr( v - 1 ) ),
If( N Items( pin_expr ) > 0,
            Eval(
                Substitute(
                        Expr(
                    Expr( __pin_expr__ ), Name Expr( pin_expr ),
dt = open("$SAMPLE_DATA/Big Class.jmp");
dt << select rows([1, 10, 21, 30, 40]);
	Size(658, 556),
	Show Control Panel(0),
pins = {};
gb << inval;
frame = Report(gb)[FrameBox(1)];
For Each({currow}, dt << Get Selected Rows,
	Eval(EvalExpr(
		Insert Into(pins, frame << Add Pin Annotation(
			Seg(Marker Seg(1)),
			Index(Expr(currow - 1)),
			Index Row(Expr(currow - 1)),
			UniqueID(Expr(currow - 1))
gb << update window;
wait(1); // demo purposes
pins << Delete;
Clanlope
Thanks jthi! really appreciate it!
Clanlope
@jthi Sorry but is there a sample way like current report / current data table to get current frame user selected?
I use this but only if the graph has the script added.
	For Each( {f, n}, frames,
		Eval( Eval Expr( f << AddGraphicsScript( Handle( ::currentFrame = Expr( f ) ) ) ) )
