Now, I asked myself: what happens if additional FrameBoxes appear - either because rows were added to the data table or because the Data filter was changed.
The Background: Some "strange" behavior of Graph Builder which I noticed before but couldn't describe precisely enough to get a hint "why": Sometimes settings are "inherited" automatically when a plot is split into subplots, sometimes the user has to set the settings again for the subplots.
The surprising answer (If generalization from 2-3 examples is right): 2 examples later ...
Some findings (but: full picture is more complicated)
- If there is a tiny difference between the settings of the existing FrameBoxes (1st example: different Fill Selection Mode), the settings are not used for additional FrameBoxes -- not even settings that were identical (Backgroundsetting) .
- If ALL settings of ALL existing Frameboxes are exactly the same, this common set of settings is used for the new FrameBoxes as well.
This is illustrated in the second step: the GraphBuilder is restricted (again) to 2 FrameBoxes, but now the Fill Selection Mode setting is matched for both FrameBoxes. Now, all settings are the same - and when the Data Filter is removed, the common set of settings is used for the new FrameBoxes as well.
Created:
Oct 28, 2022 04:03 AM
| Last Modified: Oct 28, 2022 1:09 AM(2553 views)
| Posted in reply to message from hogi 10-27-2022
"sometimes the user has to set the settings again for the subplots."
This reminds me of another behavior of GraphBuilder which I could not understand so far:
If the color/marker settings of a plot are adjusted "manually", sometimes such settings are copied to new subplots, sometimes the user has to adjust the settings again for the new subplots.
In addition: Changing the order of the varaibles on the axis can reset the color settings.
digging deeper: starting with 2 or more variables on the axis with "cloned" color/marker settings. If additional variables are added to the axis, the color/marker settings are cloned again.
But: If the new variable is added
- far to the left on the X axis
- on top of all varaibles on the Y axis
the settings are not copied. And in addition: all previously cloned color/marker settings are reset (!!!)
So - with some hope - the bugs will be fixed with the next Jmp update ...
In the meantime, is there a trick to reset the axis labels?
For changing the color of the graph elements, you can use Revert from the right-click context menu:
for the Axis Scale, there is Revert Scale:
and for the axis setting there is Revert Axis - but this command doesn't reset the axis label :( Is there a command that works for the axis label as well?
For simple plots, I save the script and manually remove the command with the wrong axis labels. But for Dashboards, it's quite complicated because the script is so long ...
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '561289' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '561289') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '561289') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
