Created:
May 10, 2018 12:47 PM
| Last Modified: May 10, 2018 3:04 PM(7542 views)
I am using graph builder to plot three varaibles using the parallel option. I have attached the plot. I am not sure why there is no scale on y axis and what does the arrow sign mean in the top of the graph?
Thanks Mark. I will read the suggested material. The variables I am plotting are all similar scale and it works for some set of data but sometimes I don't get the scale on y axis.
The same data set works fine for JMP PRO 14 and not for JMP 13. I do however, have still problem with JMP PRO 14 for some set of data. Thanks
Thanks. I did try the Overlay plot but the x-axis is the row of the data whereas in Parallel plot x axis the y column label. I have 64 columns of data for many devices and wanted to show one graph.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '56803' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '56803') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '56803') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
