john_madden
Graph Builder composite graphs
In Graph Builder, I would like to create a composite graph consisting of four panes in a 2x2 arrangment. I'd like each of the panes to have a different y-axis, whereas both have the same x-scale. I can get to 2 rows x 1 column with overlays.
But when I double up the x axis, I'd like the overlay to go away, so I just have a single parameter in each pane. Instead I get this:
Is there a way to get 2 x 2 panes with just one column plotted in each pane (i.e. no overlay)?
John
gzmorgan0
Re: Graph Builder composite graphs
Here is an example using JSL.
Names Default to Here(1);
dt = Open("$sample_data/fitness.jmp");
gb = dt << Graph Builder(
	Size( 534, 454 ),
	Show Control Panel( 0 ),
	Variables(
		X( :Weight ),
		X( :Weight ),
		Y( :Oxy, Side( "Right" ) ),
		Y( :Runtime, Position( 1 ) ),
		Y( :RunPulse ),
		Y( :RstPulse, Position( 2 ), Side( "Right" ) ),
		Overlay( :Sex )
	Elements(
		Position( 1, 1 ),
		Points( X, Y( 2 ), Legend( 240 ) ),
		Smoother( X, Y( 2 ), Legend( 241 ) )
	Elements(
		Position( 1, 2 ),
		Points( X, Y( 2 ), Legend( 246 ) ),
		Smoother( X, Y( 2 ), Legend( 247 ) )
	Elements(
		Position( 2, 1 ),
		Points( X, Y( 2 ), Legend( 248 ) ),
		Smoother( X, Y( 2 ), Legend( 249 ) )
	Elements(
		Position( 2, 2 ),
		Points( X, Y( 2 ), Legend( 254 ) ),
		Smoother( X, Y( 2 ), Legend( 255 ) )
stan_koprowski
Hi @john_madden ,
Extending on the JSL script provided by @gzmorgan0 with the same fitness data table.
If you right-click on the axis you get an option to move the variable to the right.
You can also move the axis back with a right-click on the right-most axis and selecting move left.
And here is a video showing the interactive steps to move the y-axis to the right.
(view in My Videos)
cheers,
Stan
