Graph Builder: adjust the axes to the filtered data
Jun 23, 2023 07:04 AM(3872 views)
If a user applies a data filter to exclude rows, the Graph Builder Plot restricts the axes (and Group X/Y areas) accordingly.
... but not always: For columns with modeling type multiple response, Jmp (17.1) displays all existing values on the axis (and Group X/Y areas) - even if the data is restricted by a global data filter and a local data filter.
Is there a setting to change this behavior?
workaround (for the case with the global data filter): generate a subset and plot from there.
Seems to be somehow bugged or working inversed with multiple response columns. You could enable Show Excluded Rows (hold shift while pressing red triangle to access Show Excluded Rows).
