penalah
Graph Builder User settings
Hello everyone,
Is there a way to code that the graph builder would ask the user questions such as axis range, titles, etc.,
Appreciate your help
Thanks
Re: Graph Builder User settings
There is not a Graph Builder Wizard, that would automatically ask such questions of Graph Builder.  However, one can write such code using JSL to as those questions.  The question I will ask, is given that one can easily adjust all of those items interactively when the Graph Builder graphic is displayed, do you really need to ask those questions before the generation of the graph?
Here is a simple script that allows the user to set the max value for the Y axis.
dt = Open( "$sample_data\big class.jmp" );
nw = New Window( "user input",
	<<modal,
	H List Box(
		Text Box( "what is the Y axis max " ),
		Spacer Box( size( 10, 0 ) ),
		objMax = Number Edit Box(
			10,
			<<SetFunction(
				Function( {this}, /* put my value into my sibling's display */
					theMax = objMax << get
gb = dt << Graph Builder(
	Size( 528, 456 ),
	Show Control Panel( 0 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 3 ) ) )
Report( gb )[axisbox( 2 )] << Max( theMax );
	<<modal,
	H List Box(
			10,
			<<SetFunction(
	Size( 528, 456 ),
penalah
Thank you for your response. It's not mandatory to ask the questions but to give/look more efficient I am finding the alternatives.
Thank you for your help. It worked.
