ACraig
Graph Builder Dynamic Subtitles
Hello, I was hoping someone could help me figure out how to make it so that the subtitle of my graph would be take the min(:Year) and max(:Year) and use them in the subtitle. So, if the minimum year was 2018 and the maximum was 2025 then the subtitle would be "2018 - 2025".
mmarchandFSLR
Re: Graph Builder Dynamic Subtitles
Like this?
dt = Open( "$SAMPLE_DATA/US Regional Population.jmp" );
dt:Year << Data Type( "Numeric" );
dt << Graph Builder(
	Show Subtitle( 1 ),
	Variables( X( :Year ), Y( :Population ), Overlay( :Region ) ),
	Elements( Points( X, Y, Legend( 18 ) ) ),
		Dispatch( {}, "graph 1 title", TextEditBox,
			{Set Text( Char( Col Min( :Year ) ) || " - " || Char( Col Max( :Year ) ) )}
8 REPLIES 8
Level XIII
min / max form the local data filter - or from the whole data set?
For the Data filter, please have a look at https://marketplace.jmp.com/appdetails/Graph+Builder+Toolbar
One of the shortcuts allows you to use the settings of the data filter as title (not subtitle).
(view in My Videos)
Level XIII
To make it adjust the subtitle, go to  C:\Users\_username_\AppData\Roaming\JMP\JMP\Addins\hogi.GraphBuilderToolbar\resetAxisLabels.jsl
and change line 36 to
gb[Text Edit Box( 2 )] << Set Text( title ); // was Text Edit Box( 1 )
(view in My Videos)
Level XIII
And based on the data in the table, it is something like:
Names Default to Here(1);
:Year << data type(numeric);
Graph Builder(
	Show Subtitle( 1 ),
	Elements( Line( X, Y ) )
dt << select  where  (:year < 1950 ) << exclude(1) << select where(0);
myRows=where(dt, not (excluded()));
min = Char(min (dt[myRows,"Year"]));
max = Char(min (dt[myRows,"year"]));
((Current Report() << XPath( "//OutlineBox[@helpKey='Data Filter']" )) << get scriptable object) << Show Subtitle( 1 )  ;
current report()[Text Edit Box( 2 )] << Set Text( min || " — " || max );
ACraig
Hello, sorry for the confusion, I should have been more specific. From the whole data set. As my data set updates, I would want those dates to update as well in the subtitle.
mmarchandFSLR
Like this?
	Show Subtitle( 1 ),
ACraig
That worked wonderfully! Thank you so much!
I assume as you are talking about "dynamic" subtitles you mean when using Local Data Filter? You will have to use some script to add << Make Filter Change Handler to your local data filter.
Not sure how robust this example is, but it gives an idea of how to use << make filter change handler
gb = dt << Graph Builder(
	Show Subtitle(1),
	Variables(X(:weight), Y(:height), Overlay(:sex)),
	Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11))),
	Local Data Filter(Add Filter(columns(:height)))
// Reference to filter
ob_filter = (gb << Top Parent) << XPath("//OutlineBox[@helpKey='Data Filter']");
ob_filter = ob_filter[1];
ldf = ob_filter << Get Scriptable Object;
f = Function({a},
	dt = gb << Get Data Table;
	w = ldf << Get where clause;
	If(Is missing(w),
		minval = Col Min(:height);
		maxval = Col Max(:height);
		Substitute Into(w, "Select ", "Get Rows ");
		r = Eval(EvalExpr(Send(dt, Expr(Parse(w)))));
		minval = Min(dt[r, "height"]);
		maxval = Max(dt[r, "height"]);
	title = Eval Insert("^minval^ < height: < ^maxval^");
	gb << Dispatch({}, "graph 1 title", TextEditBox, {Set Text(title)});
rs = ldf << Make Filter Change Handler(f);
f(0); // run once
Level XIII
related discussion - with similar solutions:
Is it possible to dynamically update "graph title" based item selection in local data filter (includ...
here are wishes to add this feature to JMP - without the need for scripting:
Auto population of title - graph builder
Local Data Filter: option use the selection as graph title
the idea: the user can specify which entries of the data filter are added to the title:
