Robbb
This widget could not be displayed.
" alt = "Level III"/> Robbb
Graph Builder: Color not working for multiple Y axes
Hi everyone,
I have columns, lets call them X, Y1, Y2, and C. Column C has value colors defined.
When I open a new graph builder and drag X on the x axis, Y1 on the y axis and C on color, the dots in the plot show with the right color defined by the value colors of column C.
But when I drag Y2 and drop it on the y axis below Y1 so that I get two graphs, both show with a different coloring than what I defined in the value colors of column C.
When I then drag the column C from color to overlay, the colors show correct again for both graphs.
Why are the color values ignored for column C in "color" for multiple y axes? Is it a bug? I'm using JMP 17.0.0.
Cheers
Rob
Re: Graph Builder: Color not working for multiple Y axes
Most likely a bug, happens also with JMP17.2.0. Seems to work a bit weirdly, you can add both color and overlay with same column and then disable/enable it from variables
If your scales for the Y1 and Y2 are similar, you could stack the data and plot it that way (as a workaround).
" alt = "Level XII"/> hogi
Level XII
Will be fixed in Jmp18:
generate via:
Names Default to Here(1);
mytitle=Jmp version();
:sex << Set Property(
	"Value Colors",
	{"F" = 43, "M" = 45}
dt << Graph Builder(
	Size( 390, 386 ),
	Variables( X( :height ), Y( :sex ), Y( :weight ), Color( :sex ) ),
	Elements( Position( 1, 1 ), Points( X, Y, Legend( 12 ) ) ),
	Elements(
		Position( 1, 2 ),
		Points( X, Y, Legend( 13 ) ),
		Smoother( X, Y, Legend( 14 ) )
		Dispatch( {}, "graph title", TextEditBox, {Set Text( mytitle )} )
