lala
Level IX
How can use JSL to stop the other JSL that is currently running and execute this new JSL?
For example, the previous code has been run in a aaa.JSL, it has a long wait
aaa
dt=Open("$SAMPLE_DATA/Big Class.jmp");
Wait(100);
Now run a new JSL:bbb.jsl, how can it stop running aaa.jsl
bbb
Close  Script("aaa");//??
Close(dt,nosave);
Thanks!
Re: How can use JSL to stop the other JSL that is currently running and execute this new JSL?
You can do it by putting in a check that tests to see if a .txt file has changed.  In your second instance of JMP, you can run a simple script that changes the .txt file.
First script
Save Text File( "$TEMP/flag.txt", "0", replace );
For( i = 1, i <= 100, i++,
	If( Load Text File( "$TEMP/flag.txt" ) == "0",
		Wait( 1 ),
		Throw()
Show( i );
Script for second instance of JMP
names default to here(1);
Save Text File( "$TEMP/flag.txt", "1", replace );
