aliegner
Grab "date Modified" info from file?
So I've been handed an old .jsl file that parses a bunch of .dat and .csv files into a combined .jmp table.  It looks through several files for each lot (one per wafer) and combines it all into a single data table.  However, it was never programmed to add the timestamp from the metro tool.  How can I add to the .jsl to grab the timestamps from the files?
Any help please?
Re: Grab "date Modified" info from file?
see if the Last Modification Date function returns the information you need.  From the scripting index:
Format(
  Last Modification Date(
  "$SAMPLE_DATA/Big Class.jmp"
  "ddmonyyyy:h:m:s"
"30Jan2015:13:50:52"
edit: or the Creation Date function.
