So I've been handed an old .jsl file that parses a bunch of .dat and .csv files into a combined .jmp table. It looks through several files for each lot (one per wafer) and combines it all into a single data table. However, it was never programmed to add the timestamp from the metro tool. How can I add to the .jsl to grab the timestamps from the files?
