TriciaJF
Goodness of Fit/P-Value in Graph Builder
When doing regression line in Graph builder is there a way to get Goodness or Fit/P-Value?
Re: Goodness of Fit/P-Value in Graph Builder
Look to the Properties panel on the left side in the Control Panel after adding the regression line to the plot:
TriciaJF
Thank you Mark!  F test is not an option that I see?  I have JMP 13.0. Is that the problem?
R square is used by some as a measure of 'goodness of fit.' You didn't mention that you wanted to test significance. That test is not available in Graph Builder. It is available in Bivariate (Analyze > Fit Y by X) or in Fit Least Squares (Analyze > Fit Model).
