Residentx
Global Zip codes. Best done in JMP or SAS?
ISO has standards for zipcodes around the world. Is this feature available in JMP, SAS or Both.
I guess since this is a JMP forum, I should limit this to JMP.
Here's the ISO standard, https://en.wikipedia.org/wiki/ISO_3166-2
China I need to map. China has prefectures but they have these subvisions at the local level.
Also, is there a way to list both chinese simpllified, chinese traditional, romanized or all?
Thanks in advance.
Re: Global Zip codes. Best done in JMP or SAS?
https://www.iso.org/glossary-for-iso-3166.html
seems to be a good explainer for
https://www.iso.org/iso-3166-country-codes.html
which seems to offer a way to get some information about standard names for large regions.
I don't think it offers anything for what I'd call zip codes in the US. I believe it goes to the state level, probably not to the county or city level.
Depending what you are trying to do, you might find these interesting
https://osmnames.org/
https://www.maptiler.com/news/2016/10/osmnames-place-names-data-geocoder/
https://github.com/OSMNames/OSMNames
Also: boundaries and place names change. One or more additional counties appeared in the US during the 1980s, when SAS/Graph was producing county level maps for the first time. It was an eye-opener. https://www.census.gov/programs-surveys/geography/technical-documentation/county-changes.1980.html .  It is impossible to stay completely up-to-date. https://xkcd.com/1688/
A reminder about ZIP codes in the US is in .
Residentx
My question is whether this is integrated into JMP so I can display it in graphs. I can do this in excel now but not all areas.
Do you need me to list some examples with picture? I have files now for oblasts in Ukraine.
Pictures might help, and maybe an indication of what you've tried so far, and what you are trying to accomplish.
JMP 16 has a few maps built in (so do earlier versions of JMP.) I did this with a big class graph by right->click add a map and right-click->customize (to thicken+color the line and clip the simple earth bitmap to the border.)
Mainland China ProvincesMainland China Provinces
dt=open("$sample_data/big class.jmp");
dt<<Graph Builder(
	Size( 1190, 900 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 3 ) ) ),
		Dispatch(
			"weight",
			ScaleBox,
			{Scale( "Geodesic" ), Min( 78.9121725050727 ), Max( 131.391068563684 ),
			Inc( 10 ), Minor Ticks( 1 )}
		Dispatch(
			"height",
			ScaleBox,
			{Scale( "Geodesic" ), Min( 17.4684154783393 ), Max( 55.4083033940635 ),
			Inc( 5 ), Minor Ticks( 0 )}
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Background Map(
				Images( "Simple Earth" ),
				Boundaries( "Mainland China Provinces" )
			), Marker Size( 1 ), Marker Drawing Mode( "Normal" ),
			Grid Line Order( 3 ), Reference Line Order( 4 ),
			DispatchSeg(
				MapSeg( 1 ),
				{Clip Shape( Boundaries( "Mainland China Provinces" ) )}
			), DispatchSeg( Shape Seg( 1 ), {Color( "Black" ), Line Width( 3 )} )}
If these are not the boundaries you need, you can use SHP files to make them. I've not been through the process, but others have: https://www.google.com/search?q=jmp+shp+file shows several hits.
You might also look at the street map overlay and see if that does what you need.
Residentx
@Craige_Hales @Craig
This looks good but let me show you what I've done or tried in Excel and we'll start there. I didn't use lat/long though.
I work on JMP the next few days so I'll compare and post back.
Residentx
I recreated some of it tonight but I have to do it better. Excel has the ability to pull the shapefiles. I don't have to load them. I give the ISO code and they plot them.
Residentx
