Global Variables overwritten in a loop
I create windows in a loop following columns. For example, in the JSL example below, I create a window with the distribution and a button that temporarily hides the window for each column (Age, Weight). The problem is that as my loop progresses, my object variables are overwritten by the last window.
For example, in the age window generated by the example, clicking on the button is supposed to temporarily hide the Age window, but in reality it hides Weight because it has been overwritten.
Is it possible to do a names default to here or something like that so that each window has its own independent space without having to change the name of the variables for each window every time? Because I have a lot of them...
lstCols = {"age", "weight"};
For Each( {value, index}, lstCols,
	colref = Column( value );
	window = New Window( "Window - " || value,
		V List Box(
			distribution = dt << Distribution( Column( colref ) ),
			Button Box( "Hide",
				window << show window( 0 );
				Wait( 2 );
				window << show window( 1 );
Re: Global Variables overwritten in a loop
You can use window scope
nws = {};
For Each({value, index}, lstCols,
	colref = Column(value);
	nw = New Window("Window - " || value,
		V List Box(
			window:dist = dt << Distribution(Column(colref)),
			Button Box("Hide",
				window:dist << show window(0);
				Wait(2);
				window:dist << show window(1);
	Insert Into(nws, nw);
For Each({nw}, nws,
	Show(nw:dist << Get Window Title)
You could also evaluate the reference to the button script/function or use slightly more complicated function within the button to take scoping into account.
Mittman
Mittman
Below is a solution that isn' as elegant as @jthi 's answer, but more intuitive from my perspective.
windows = Associative Array();
	Eval(EvalExpr(
		windows[value] = New Window( "Window - " || value,
			V List Box(
				Button Box( "Hide",
					windows[Expr(value)] << show window( 0 );
					Wait( 2 );
					windows[Expr(value)] << show window( 1 );
The associative array "windows" provides a container that maintains references to the different windows and "Eval(EvalExpr(...))" is used to make sure that a particular button's script isn't evaluating the current "value" but the one in the scope when it was created.
