Kenobi
Getting rid of footnotes at end of graphbuilder
I am working on the Cities dataset to build a journal of GraphBuilder objects. I have excluded a few rows, and it is clearly visible at the bottom of the graph (as shown in the image below) as "where 4 rows excluded". This has been built interactively, and I can remove the footnote manually. But since I am using a script, I want to incorporate a line in my code that does not show this footnote. Is there a way possible to achieve this?
Thank you.
Level XIII
Re: Getting rid of footnotes at end of graphbuilder
Yes, just include
Show Footer( 0 ),
in the GraphBuilder script, like Show Legend(0).
If you found a way to apply the settings interactively via mouse clicks, you can then save the script via
and check which JSL command is used.
By the way: mouse clicks ...
there are thousands of easter eggs hiding:
CTRL/Alt/Shift + click/select/double click/right click
I usually use XPath when hiding that text box
dt << Select Rows([1,2]) << Hide and Exclude(1) << Clear Select;
gb = dt << Run Script("Graph Builder Line and Bar Charts");
wait(2); // For demo purposes
where_tb = (gb << Top Parent) << XPath("//TextBox[contains(text(), 'Where(')]");
where_tb << Visibility("Collapse");
Kenobi
Thank you for your reply.
Would it be possible to incorporate it in this script? I am trying to append GB objects in ListBox.
Graph Builder(
	Size( 534, 456 ),
	Show Legend( 0 ),
	Variables( X( :Region ), Y( :OZONE ) ),
	Elements( Points( X, Y, Legend( 7 ) ) ),
		Dispatch(
			"Graph Builder",
			OutlineBox,
			{Set Title( "OZONE vs Region" ), Image Export Display( Normal )}
		Dispatch( {}, "graph title", TextEditBox, {Set Text( "" )} ),
		Dispatch( {}, "X title", TextEditBox, {Set Text( "" )} ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Marker Size( 5 ), Marker Drawing Mode( "Normal" )}
mmarchandTSI
(gb << Report)["Graph Builder", Text Box( 5 )] << Visibility( "Hidden" )
With "gb" being your Graph Builder platform, this seems to work.  I am not positive that it is always number 5, though.
Level XIII
If you don't need the Footer at all, you can also disable it in the Preferences :
Kenobi
Thank you for your reply. But I want to incorporate this as a functionality in an add-in that I am creating. It will be used by other team members, hence need a script to allow this.
Level XIII
Yes, just include
Show Footer( 0 ),
Kenobi
Thank you very much. This works like a charm. Also, appreciate the link to shortcuts.
