nil
nil
Getting mode statistics in tabulate
Hi JMP user community,
I have periodic inprocess record for batches manufactured, monitoring frequency is every 15 mins.
I have to calculate batch specific mode for the respective in-process entry.
I can't see the option of mode statistics in Analyze > tabulate. I am using JMP 14.3.0.
Is there way to get Mode as statistics using tabulate.
Thanks!
Re: Getting mode statistics in tabulate
Mode is not available in Tabulate, however it is available in Distribution, and with a little JSL, it can be added to your Tabulate table.  All it takes is to precalculate the MODE and then add it as a new column into your data table.
The missing values are because for those heights, multiple mode values were found.
Here is the JSL
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
dis = dt << Distribution(invisible,
	Continuous Distribution(
		Column( :height ),
		Customize Summary Statistics( Mode( 1 ) )
	),by(:age)
dtstats = report(dis[1])["Summary Statistics"][TableBox(1)]<<make combined data table(invisible);
dis << close window;
dtstats << select where(:Column 1 != "Mode");
dtstats << delete rows;
dtstats << delete columns({"Y","Column 1"});
dtstats:Column 2 << set name ("Mode");
dtstats:age << data type(numeric)<<modeling type(ordinal);
dt << Update(
	With( dtstats ),
	Match Columns( :age = :age )
close( dtstats, nosave );
dt << Tabulate(
	Change Item Label( Statistics( Mean, "height" ) ),
	Show Control Panel( 0 ),
	Add Table(
		Column Table( Statistics( Mean ), Analysis Columns( :height ) ),
		Column Table( Statistics( Std Dev ), Analysis Columns( :height ) ),
		Column Table( Analysis Columns( :Mode ), Statistics( Mean ) ),
		Row Table( Grouping Columns( :age ) )
nil
nil
Thanks for the script!
This is helpful..
