Kenobi
Get the JMP Default Dark color theme
Is there anyway I could extract all the color codes used in these color themes, using JSL or any another way?
I do have difficulties in dealing with colors, hence I rely more on HEX codes, or numeric codes.
Thank you.
0 REPLIES 0
